I managed to sort this out today before I hit "post" for help, but here is the problem and resolution:
95 850 R with factory amp at radio/heater core area and CD player in trunk.
Radio fuse (#7) blows instantly, key on or key off doesn't matter. Constant 12V across the socket according to my meter.
Removed radio and ECC unit and an't see any frayed wires at all in the radio/climate area.
What I did
- searched a bunch of old MVS threads
- found a post in this one really useful, by fazool (viewtopic.php?t=45058) explaining that power comes in from fuse #7 on two red-black wires
- after a series of "well it's not that" attempts (unhooking radio itself, CD player, etc. connectors) I figured out that unplugging the amp solved the problem. Amp is accessed from the driver's footwell.
Looks like a dead amp, not sure I will ever get to investigating that any further. Since the amp harness just plugs in between the regular harness, I could easily just switch back to un-amped setup and the radio makes noise again.
95 850 radio fuse #7 blown constantly, always 12V at fuse Topic is solved
- Has thanked: 311 times
- Been thanked: 817 times
Option for MVS member amp repair: viewtopic.php?f=6&t=91782
- 2929 Views
Last post by 93SCMax
- 1139 Views
Last post by Brucebo
- 155 Views
Last post by jonesg
- 24 Replies
- 12272 Views
Last post by mikkowus
- 1390 Views
Last post by Joffwillson
