Hi guys
First and foremost Happy Holidays to all
Been quite busy, so have not been around much.
My 99s 70 T5 lost all power to radio, I checked fuse 7 (I believe) and alas was blown, replaced the fuse and it blew right away.
I disconnected the radio wiring, amp, power, speakers, etc, in short radio out, placed another fuse and it blew again right away.
Did a quick search but no real answers to the problem. My guess is a short, or maybe some trickery under the fuse box, before I start witch hunting down the culprit, any clues or hints on what to look for?
This happened out of the blue, although my wife tells me a couple times the radio went into code in the past weeks, and last saturday the car had not power which I solved by giving a shimmy to the battery cables althought they seemed tight to me
Thanks in advance for the help
Radio fuse keeps blowing (#7)
elchopperfreak
- Year and Model: S70 T5 1999
fazool
- Year and Model: S60, 2007
- Been thanked: 7 times
I would assume it must be a short. If it were a stuck relay that would simply deliver power when on, etc. If the radio went into CODE previously, it lost power. All things point to a short in the cable feeding power to the radio itself.
The only like locations for such are where they go through metal openings or rub against a metal edge.
Sometimes a wire can pull out of a connector and flop around but that would cause loss of power always.
I just looked over the wiring diagram here in the MVS repair databaase. Fuse 7 feeds a red/black wire to connector pin 10 of the 53-pin instrument panel engine compartment connector #24/13
This then branches out from there to TWO red/black wires which BOTH feed the radio. Dunno why there are two.
Here is a very very simple test for you to do.
Pull the radio out and unplug the connector on back. Run a simple continuity check from the two red/black wires to ground. One of them is likely shorting.
Do this with power off. If it doesn't short then, turn your power on and try it again. This will help determin if it is upstream of the relay and switches.
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
Volvo Manic
- Year and Model: V70,2000
My problem with fuse 7 just started. My radio pins all test correctly, do not seem to be shorting out.
Even with the radio control head disconnected my fuse blows immediately. There is a strong spark that jumps out as the fuse touches the contacts, instantly blowing the fuse well before being seated.
I need to disconnect my aux CD changer next. Does anyone have other ideas or seen this fuse 7 type problem before that is not in the radio control head?
precopster
- Year and Model: Lots
- Been thanked: 128 times
In my 98 V70R it wasn't the radio blowing the fuse as it still blew without it being plugged in. I have the SC900. The connector going to this radio has 2 green/red wires for power. One is going to the radio and the other is connected directly to it and feeds the amp circuit.
Next on the list is the under seat amp; scarce and expensive.
- 2026 Views
Last post by 90 Beater
- 1395 Views
Last post by SuperHerman
- 2109 Views
Last post by nthnnxn
- 1981 Views
Last post by doublebug
- 3623 Views
Last post by sailorbob74133
