Power Steering Fluid?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 151 times
Been thanked: 4 times
Post by Mr. Detail »
I need verification for refilling my power steering reservoir that has a leak that has been bad enough that it is bone dry. My car manual says that it takes the same fluid (3309) as my ATF fluid. Can anyone verify that this ATF fluid should be used in the power steering reservoir?
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
It likely had the green Volvo power steering fluid originally. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
Mr. Detail
June, thanks for your response. I should have done this first but I just called my local Volvo dealer and they gave me this part number (#30741424) as the correct fluid to fill up with. This looks to be the "blue-green" stuff you mentioned.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
There has been some debate on this, my take is Volvo did a mistake both in the manual and on early reservoir caps that were calling for transmission fluid. In both early SMI and later ZF racks, I would only use the green looking Pentosin
I believe VW dealers also sell a rebranded Pentosin bottle which may be more affordable.
The 11s is the older formulation of the fluid, while the 202 is the later one. Very little differences but a 202 may be more 'fresh' off the shelves
https://www.fcpeuro.com/products/hydrau ... 1s-1-liter
https://www.fcpeuro.com/products/hydrau ... 02-1-liter
Mr. Detail
Just a follow up from yesterday on this topic. I went out to my car last night with an extended "Q-Tip" and when I dipped it in the PS reservoir and pulled it out I was surprised to see a "honey brown" colored fluid. Can the blue-green fluid turn this color if it is too old? Now I wonder if I have to drain the whole system and start over.
oragex
Post by oragex »
I've seen your color a few times at the junk yard cars. It is not the Pentosin, not does it look like a 3309 Atf
