Mileage ~170k
Started car other morning - running very rough - CEL = P0300, P0304& P0305.
Started checking coils - 1&2 sparking fine - then and I don't know why I didn't finish checking the other coils, decided to do a compression test.
1-3 = 150
4 = 135
5 = 120
Go back out today to finish checking coils 3-5 and not getting a spark. Checked 1&2, which were good yesterday, but no spark this morning. What am I missing? Did I blow all the coils when doing the compression test because I didn't disconnect them?
Silly question, but plugs (all very corroded btw, picking up new ones right now) don't need to be in cylinder when doing a spark test right - not some kind of fail safe where computer detects no plugs so doesn't bother sending electricity to coils?
Thank you.
2006 XC90 2.5T - couple things...
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
To check any coil - try disconnecting the injector rather than the coil itself www.youtube.com/watch?v=nDwtZCWU7u8
I think they are made by Bosch
You'll need to replace the spark plugs - when worn they cause the coils to fail
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
For coil pack, Bosch PN 0221604008 is the OEM version of the Volvo PN 30713416 at about 60% of the price.
wanderdüne
- Year and Model: 2004, 2006 XC90 2.5T
- Has thanked: 6 times
- Been thanked: 45 times
Check to see if you are getting fuel pressure at the rail. Use a rag to catch spray/excess fuel and depress the shrader valve on the fuel rail.
bfry
- Year and Model: 2006 XC90 2.5T AWD
- Has thanked: 31 times
fuse 10 was blown - replaced and gtg - somehow musta blown when doing the compression test yesterday and would explain why no spark today. Running smooth now...
Thank you for the responses.
- oragex
Good fix! May look at the wires to the coils, sometimes the insulation may crack and touch the metal, or may get crushed under the black cover. Also good to look at the engine ground wire, I believe somewhere behind the top of the engine, close to the timing belt side
- 458 Views
Last post by erikv11
- 16 Replies
- 3537 Views
Last post by Georgeandkira
- 1669 Views
Last post by Reinie
- 2287 Views
Last post by oragex
- 1103 Views
Last post by cn90
