Volvo V70 2008 w/3.2 non turbo
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
EddieW2017
Year and Model: 2008 V70
Post by EddieW2017 »
Question, recently my 2008 v70 with a 3.2 left me on the side of the road with the Battery light lit on the dash and the car just stopped. After I got it back home and with some research and a new battery I found out that the BOLT holding on the Alternator gear came loose. I replaced the Gear and Bolt from FCP euro and used Locktite when I installed the new parts.
So the issue I'm having is during the re-assembly of the Intake manifold I must have broken the tab on one of the connectors to the Intake Manifold. I am not too sure what the connector actually connects into but it is located about midway up on the RIGHT (passenger side) of the intake manifold and is easier to access from under the car. I will attach a photo if I can. The wires are OK, it's just the back plastic connector part that snaps and holds the wires in place. ANYONE know if or how I can get a replacement one? I don't want to tape or ?
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 115 times
Been thanked: 185 times
Post by pgill »
Please confirm that you are talking about the red arrow
That's the MAP sensor in case you are interested
I think the connector is 30658215
Good Luck
Paul
EddieW2017
Actually YES I am, the Red arrow. thank YOU
pgill
Post by pgill »
A link to the connector that I think you need
https://www.volvowholesaleparts.com/oem ... u-30658215
EddieW2017
Sorry to bother but I also need ONE Connector for one of the Fuel Injectors that I found out isn't correctly attached. Would you happen to know the part # for this as well?
