These full page ads
Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 133 times
These full page ads
Post by Rattnalle »
I've noticed an issue with the full page ads that appear every now and then, picture below. When I use the red dot to go to the first unread post the dot makes the browser not only not go to the right post but when the page loads every post is marked as already read, making it impossible to see which was the first new post. Anyone else? Attaching browser info as well.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1248 times
Post by matthew1 »
Hi Rattnalle, what page are you starting on? I need to be able to re-create this to solve it.
Also -> Amazon link
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Looks like hijacked web browser or push notifications.
Rattnalle
Post by Rattnalle »
matthew1 wrote: 24 Nov 2019, 13:44 Hi Rattnalle, what page are you starting on? I need to be able to re-create this to solve it.
The new posts list. They only appear occasionally though.
Rattnalle
Post by Rattnalle »
RickHaleParker wrote: 24 Nov 2019, 21:22 Looks like hijacked web browser or push notifications.
I guess that's for Matthew to say "oh no those don't belong to the page" if that's the case :D
And now I managed to hit "resolved" instead of "quote". Sausage fingers and little buttons..
matthew1
Site Admin
Post by matthew1 »
Rattnalle wrote: 24 Nov 2019, 22:10 And now I managed to hit "resolved" instead of "quote". Sausage fingers and little buttons..
Hi Rattnalle,
You can unsolve a post (and thus, topic) the same way you solved it:
Mobile
Tap the solved button. It says "Set topic as unsolved"
Desktop
Click the checkbox, which will be red because you're unsolving it.
Also -> Amazon link
matthew1
Site Admin
Post by matthew1 »
Rattnalle wrote: 24 Nov 2019, 22:03
The posts list... would you mean the index for each forum? Like for this forum we're in: viewforum.php?f=4 ?
Whatever the case, the ad is expected behavior. It's part of the automatic ad serving done by Google's AdSense platform.
I'm concerned there's a problem... that the ad causes every post is marked as already read, as you wrote.
EDIT: I can't re-create this scenario of every post getting marked read. I'm on mobile Chrome.
Reason: add EDIT
Also -> Amazon link
Rattnalle
Post by Rattnalle »
I suspected the ad was fine in itself :-)
I mostly read using the "New posts" link in the hamburger menu top right. The one showing recent activity on all subs in one place.
Occasionally the ad shows up when navigating to a thread. If I've used the little red dot to go to the "first unread post" the page loading after the ad will leave me at the top with no post on the page marked as new, again with the red dots, anymore. If the ad doesn't load I get dropped at the first new post and it's marked as new.
matthew1
Site Admin
Post by matthew1 »
I’ve gotten the scenario you describe today, but no error. The unread links remain red — unread. Let’s chalk it up to anomaly, and I’ll look at it again if it happens often, disrupts your use of the forums, or both. Sound good?
Also -> Amazon link
Rattnalle
Post by Rattnalle »
Sounds good. Part of the reason I posted was to see if anyone else has the same issue. I'll report back in a few days.
