Rough idle on cold starts
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Coffin88245
Year and Model: 1988 245
Post by Coffin88245 »
Just installed the Bosch 3 injectors on my 88 245 n/a.. idle and throttle response has improved tremendously. Unfortunately it now seems to have a pretty rough idle on cold starts.. after u give it a little gas and warm it for a short period of time it smoothes out and runs like a champ.. any ideas as to why this would be happening..?
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
Coffin88245 wrote: 02 Dec 2019, 11:09....any ideas as to why this would be happening..?
Mismatch of injectors installed to LH's default fuel program....so, once started, increase RPM for say twenty seconds, then back off throttle.
Once heated O2 sensor is active, LH "sees" the richness, and decreases fuel pulse duration for decreasing fuel input.
Coffin88245
Any way to fix the issue with a tune..? They are not performance injectors just stock upgraded as far as efficiency.
