Hi Guys,
Has anyone tried to install a boost gauge and dump valve on a S40 T5. Has it worked? Does it affect the engine in any way, etc.
Your comments
S40 T5 Turbo Gauge
- Has thanked: 17 times
- Been thanked: 35 times
Should work fine...don't see how it would be any different than how it's done to any other FWD Volvo...just tap into one of the vacuum lines (buy a T-connector) and run the hose up through the pass-through below the steering wheel from the fire wall into the cabin and up to the A-pillar or wherever you want to install the gauge. As for the blow-off valve, you can read up on its installation at www.volvospeed.com Click on the message board. If there is nothing about the S40, look in the 850/70 series section...there is plenty there in the Mod section. Good luck!
