Hello, I've read through several posts regarding ATF flush and I'd like to attempt it myself. I have a '01 S60 2.4T. My question is, where does the transmission line connect to the radiator? From what I can see, I think it look's like its on the drivers side - up top. If this is it, how do I remove it? I read the posts where you need snap ring pliers to remove the metal clip to remove the hose, but this does not look like a clip I can remove. It looks like a metal coupling with some plastic green tabs sticking out. Thanks for any help!
Tony
n00b ATF flush questions
Hey, tony!
Best post I ever seen on the subject, complete with pictures. Addresses the "green plastic tabs", too!
http://www.volvoxc.com/forums/showthread.php?t=5668
'01 V70 T5
