My Volvo s80 is very low
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
Silvershadows
Year and Model: 1993 S80
Has thanked: 1 time
Post by Silvershadows »
My Volvo s80 is very low to the ground please what can I do to make it higher guys I need help Thanks
Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
Probably tired springs and shocks. Replacing both made my V70 about 2-3 cm higher overall. It's lowered itself a bit of that again though..
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
Silvershadows wrote: 16 Jan 2020, 08:04 My Volvo s80 is very low to the ground please what can I do to make it higher guys I need help Thanks
Do you mean a 2003 rather than 1993 S80 as in your profile? The HD spring should help restore height for all 1st Gen S80. Unless you are bottoming or always overloading I wouldn't worry too much if the ride is still good. Shocks and Struts are what will help with the ride more so than springs unless they are damaged or really really worn which is unusual. Height is what is loss most of the time on worn springs.
140178 - Lesjöfors - Rear HD Coil Spring S60/S80 P2 - 30748395 - I don't need this for my 03 S80
https://www.ipdusa.com/products/21877/1 ... 0-30748395
As for the front I am hoping these will restore some height once I installed them in the coming week.
https://www.ebay.com/itm/Set-of-2-Front ... %7Ciid%3A1
Rattnalle
Post by Rattnalle »
HD/reinforced springs are only really needed if you often drive the car heavily loaded and/or with a bike rack or trailer. For me it's a godsend since the car even with 100 kg on the tow hitch still behaves perfectly normal. Before it'd feel very strange. Especially with luggage inside as well.
Silvershadows
Has thanked: 1 time
Actually am not too sure of the exact year, this is the VIN/YV1TS6IE9X1043033 of my car. Please what's the production year. Because of the bad roads we have when ever the car is loaded it touches the ground on bumpy road. Can I replace the coil springs with XC90 springs.
Rattnalle
Post by Rattnalle »
No you need S80 parts if you've got an S80. But with bad roads your shocks are probably spent and you will get ride height and and comfort back if you replace them.
Silvershadows
Has thanked: 1 time
YV1TS6IE9X1043033 this is the VIN of my car how do I get to know the production year Thanks
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1001 times
Post by volvolugnut »
Your VIN decodes as 1999 S80.
Silvershadows
Has thanked: 1 time
Volvolugnut Thanks so much for the information. And thanks to all you guys for your help
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Silvershadows wrote: 17 Jan 2020, 03:55 YV1TS6IE9X1043033
It is a 1999 S80 with Engine B5244S, Transmission AW55-50SN.
