Hello,
Does anyone know if seat base foams from vehicles without heated seats are the same as heated seat optioned cars? i.e. Do they have the holes for the thermostat and the fixings for the heater pads?
Cheers,
Cookeh
Quick Q regarding seat base foam Topic is solved
- Stu70
- Year and Model: 2006 Sonic VR GT
- Has thanked: 34 times
- Been thanked: 26 times
Yes they do have holes for thermostat. I fitted EBay pads when I was retro fitting for heated seats on my non heated fronts (and also did the rears, would have done the third row seats, if a had ‘em) I included a 47 degree c cutout from RS components that fit perfectly.
I just had to make a small hole in the back rest leather to bring the wiring through, otherwise it pulled the pad when seat was laid flat and forward on the passenger side.
I used double sided tape to hold them down, cross wise between the metal bars in the foam. They aren’t going anywhere under that taunt leather/vinyl.
Controversially, I used hog rings to put skins back on and not cable ties...
1998 S70 10v BiFuel - Sold
2006 Sonic V70R - “this is going to be expensive “
- 1431 Views
Last post by Klausc
- 606 Views
Last post by mrbrian200
- 514 Views
Last post by Clemens
- 1464 Views
Last post by Ben850
- 13 Replies
- 4148 Views
Last post by JDS60R
