Just got 1999 V70R with 212k and car starts/idles fine for the first 10-15 min. and then begins to stumble/idle rough. Runs fine above 2000 rpms. No codes in on VIDA scan, also It has new XeMODeX ETM installed by previous owner and it was programmed by the dealer.
Looking for help and suggestions and idea how to tackle this problem.
99 V70 R rough idle after warm up and stalls Topic is solved
- Has thanked: 987 times
- Been thanked: 1075 times
Look for vacuum leaks using WD40 or other flammable spray on hoses and intake manifold gasket areas. Minor leaks are noticed as rough idle and clear as throttle is opened. Don't start a fire!
Old vacuum hoses are prime suspects. Hard plastic flex intake tubes are next suspect.
- kklepack
- Year and Model: 2016 XC60
- Has thanked: 12 times
- Been thanked: 5 times
Thank you for the recommendation I will try this or smoke test this weekend if weather permits.volvolugnut wrote: 20 Jan 2020, 10:09 Look for vacuum leaks using WD40 or other flammable spray on hoses and intake manifold gasket areas. Minor leaks are noticed as rough idle and clear as throttle is opened. Don't start a fire!
- Has thanked: 2199 times
- Been thanked: 1851 times
Be aware, that Xemodex warranty only refers to original owner. I found this out the hard way...........
- kklepack
You are correct. PO bought it from IPD and that info I found on their site. Did you reached out for warranty service to XeMODeX? Did they help? Did you have to buy a replacement ETM from them?scot850 wrote: 22 Jan 2020, 12:01 Be aware, that Xemodex warranty only refers to original owner. I found this out the hard way...........
Richard99
- Year and Model: 2000 V70XC
- Has thanked: 26 times
- Been thanked: 23 times
I doubt it's a vacuum leak if it only occurs after 10-15 min. A large vacuum leak leading to intake manifold would cause rough idle all the time, usually with a surge in RPM at start up.
I suspect an issue with the ETM.
Eric
1998 Volvo V70 - rear-ended and totaled
2000 Volvo V70XC
2007 Volvo V50 T5 AWD M66
2000 Volvo V70XC
- kklepack
So this morning I started up and ran fine and after few 2-3 minutes rough idle started and car died. I restarted again and same symptoms. I also disconnected MAF sensor and no improvement. I will order PCV kit and when it arrives I will check ETM and will try to replace all vacuum lines. Does fuel pressure has something to do whit this?
It was not for the ETM but the brake ABS module. That was when I found out about the ETM warranty as well. Replaced the ABS with one from Matty at Mid-West ABS. Way cheaper and better warranty!
So far ETM has been ok.
My 'R' had not been run in a while and even though the battery was on a trickle charger I knew one of the cells was weak. Car barely ran and ran like it was on 4 cylinders. 2nd start did not have enough power to turn over!! New battery and all went back to normal with sweet running.
So make sure your battery is good on all cells as the 99- cars don't like low powered/weak batteries.
- kklepack
Update: I fired up the car tonight and seems like coolant is in the oil. Take a look at the photo. Am I correct? Or is it some kind of condensation since car ran for few minutes in cold weather. Also seems like coolant level raised when engine got worm. When engine was cold the level was between MIN and MAX. Is it worth spending my time on it or find an another engine?
That looks like cold running condensate , not coolant
Pull the dipstick and look for chocolate milkshake vs brown or black oil.
- 16 Replies
- 8366 Views
Last post by valvolvo70
- 7669 Views
Last post by enriquepr21
- 1506 Views
- 720 Views
Last post by Vovo_merz
- 1257 Views
Last post by jonesboy1983
