Fluid leak under drivers seat
Yellowdog
Year and Model: 2006 V50
Post by Yellowdog »
My 2006 V50 is spewing frothy liquid from under the drivers seat. When the car is started about a 1/2 cup of liquid pours out and once at idle it seems to spurts out occasionally. Could this be caused by a clogged AC drain? If so what the best approach for fixing it. Thanks!
Yellowdog
Post by Yellowdog »
I found this video. This is what it looks like. There is also a post on UK forum https://www.volvoforums.org.uk/showthread.php?t=255776 If anyone has had a similar problem please let me know.
Thanks!
Yellowdog
Post by Yellowdog »
This was an easy fix, it was the AC drain. Passenger side (LHD). Pulled up the carpet and exposed the drain. Used a compressor to blow out the the drain. No issue since.
Yellowdog
