Working on my nephew's '08 XC90 V8. He mentioned that the AWD didn't work so I crawled under to take a look and do some basic diags. Haldex seemed fine (applied 12V to the pump and it sounds fine), Differential seemed fine but then I grabbed the driveshaft with the vehicle in Park. It spins freely. No noises coming from it and the vehicle works great as a FWD but I expected the driveshaft to be locked. I then used an extended arm camera and had my wife start the vehicle and move it a little in Drive and then Reverse. The driveshaft didn't move.
Safe to assume the Angle gear is shot?
Question - AWD diagnostics
wanderdüne
- Year and Model: 2004, 2006 XC90 2.5T
- Has thanked: 6 times
- Been thanked: 45 times
If the propshaft spins by hand when the wheels are on the ground, then the either the sleeve is stripped or worse. Either way; that's going to be a job. The rear end engages electronically when needed.
See: viewtopic.php?t=84093
https://forums.swedespeed.com/showthrea ... gle-Gear-)
tjmotter
- Year and Model: 2008 XC90
Well.... The local dealer is happy to fix it. $2082 for labor and $5465 in parts. I guess this XC will spend the rest of its life as a 2WD.
They wouldn't give me a price breakdown on the parts but I know I can get a brand new Bevel gear from the VolvoWebstore for ~$1600 and the coupling that causes the issue is ~$150 so I'm guessing they simply didn't want to do the work.....
wanderdüne
You can buy the parts from Tasca or another dealer online and have your local dealer install; that would be covered by the warranty as far as I know? Maybe someone will confirm this?
- 52 Replies
- 14318 Views
Last post by Caberguy
- 1307 Views
Last post by esl_97_850_T5
