I haven't posted here in forever, but my trusty 850 is having an issue that I'd like some advice on how to proceed. 1997 850 N/A, manual trans, 270k miles
Cylinder #3 misfire, for the last 5 months now. Runs very rough at idle, has no power on hills. Spark is good, fuel is good.
I did a dry compression test today (finally warm enough to work outside), and the numbers are (1,2,3,4,5):
194, 195, 60, 169, 145
This is bad, and I'm suspecting a burnt valve on #3. The car has used oil the whole time I've had it (6 years), about a quart every 1000 mi. I've tried to keep up on this, but there have definitely been times when it was run quite low for a while.
No signs of oil in the coolant, so head gasket probably fine, yes?
So basically, should I look into getting the engine replaced? I can't do any big work myself, so this would mean dumping quite a bit of money into it. However, the rest of the car is in great shape, and I like driving the stick shift wagon
Thanks!
