The day before Thanksgiving a recall was announced, though don't get too excited. It only involves the software.
Prior to this the deal was that when you come in for service we will upload new software. Then the added, 'at your request'. Now a notice will go out to all that have NOT had the software uploaded to come in to the dealer and have it done.
So as it stands now you have the 10-year or 200,000 mile warranty and new software. The new software allows for greater tolerance on the internal parameters and will cause fewer cases of surging and hesitation. Also there will be a warning before the car goes into the limp home mode. Another item is that the throttle will not move as much on its own (dither) so the wear will be less.
With the new software there are far fewer claims being made to NHTSA.
To my knowledge there will be no further redesign of the ETM, but with a warranty replacement with PN 8644347 and the new software most of the problems should be minimized. NHTSA is still following complaints as they come in. http://nhtsa.dot.gov.
If you are in Canada make sure that VCNA will cover you. If you are overseas you are NOT covered by the warranty and probably not by the software recall. Australia just got the dealers to install the new software at no charge.
If you are overseas try small claims court like Andy did in the previous message, "Judge says ETM not suitable for intended purpose."
Don Willson
[email protected]
VEXEDvolvo.org
Volvo issues a recall in the US.
DonWillson
- Year and Model: 2000 V70XC
Announcing my affiliation with XeMODeX, Inc. as Internet correspondent and consultant to Volvophiles needing help with failing ETMs. See http://FixYourETM.com. For the full history of this problem see http://VEXEDvolvo.org
- 7710 Views
Last post by shiloh51933
- 1930 Views
Last post by PeteB
- 20 Replies
- 17322 Views
Last post by Hurtfeelings
- 5434 Views
Last post by chrism
- 1218 Views
Last post by E Showell
