Pass. side door lock
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 151 times
Been thanked: 4 times
Post by Mr. Detail »
Heh guys;
Hope all of you are well and stocked.
Just wondered if anyone can tell me why when I unlock the drivers side door with my key the only door lock that won't open is the front passenger side. I don't use the remote right now. Is this a fuse issue or something else?
Thanks!
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
passenger door module issue, probably has an error code?..does it lock??..if its just not unlocking it could be a mechanism or wiring problem
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
Mr. Detail
No error codes. I can lock it manually but it won't lock and open with the key or via the driver's side door button.
darrylrobert
what are you using to check for codes?..i would say you have a bad connection/wiring or bad lock module or the solenoid, if it makes a weak attempt to move its the solenoid
Mr. Detail
darryl;
Where is the lock module and the solenoid located? Behind that door panel?
If I need one of those, I assume that I will have to go to the dealer. :(
Wardhill
Year and Model: 2001v70 xc
Post by Wardhill »
I had the same problem.removed the door panel, easy, and unplugged the module and plugged it back in like it needed a reset has been fine since
Mr. Detail
Wardhill, any instructions on removing the door panel? Not sure where to begin.
