'99 V70 2.4 NA - O2 sensors battle
fszczesniak
Year and Model: V70 1999
Has thanked: 3 times
Post by fszczesniak »
Long story short, the fuel efficiency got really high lately - 14L/100km, so i started to dig into it. Just renewed my PCV, btw.
after a short diagnose with OBD Fusion, I noticed that my O2 sensors are not working correctly - S1B1 was stuck on about 0,5V and not reacting properly while driving. STFT's and LTFT's were also to high.
Got a new OEM sensor, installed it yesterday, engine is running smoother and nicer now, but the S1 is still stuck at about 0,5V! S2 post-cat on hot idle runs at about 0,85V....
I started measuring the voltages on the plug with my multimeter and got only 3,8V between battery negative and S! signal+ with the ignition on... what the heck is going on here?
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
14l-15l/100km with automatic transmission in city traffic sounds normal to me.
If it is manual...then around 13l/100km.
I guess that it is a 20v car.
Did you removed negative battery cable for 10-15min after o2 sensor replacement...in order to reset ECU and fuel trims?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
fszczesniak
Heh, it used to be around 11/100 :-) now even a very calm highway trip is not going under 10...
Yes, I did the reset procedure. Actually, during the lambda sensor replacement, the battery was disconnected the whole time.
P.s. yes, it's a 20v engine, non turbo, with ETM
misha
Post by misha »
At highway speeds 120-140km/h it should be from 8.5l to 10l/100km.
*With automatic transmission
You mentioned that you replaced pcv system....could be that you forgot to connect some of vacuum hoses....creating a vacuum leak.
Or worst....intake manifold gasket not seated properly.
Did high consumption appeared right after pcv job?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
fszczesniak
I checked everything several times - was not my first pcv job :-) definitely vacuum hoses coming out from the intake manifold are in need of replacing, obd2 shows about 32kpa manifold pressure (don't know the specs). Planning also to smoke test the air intake, vacuums and exhaust in the nearest future
misha
Post by misha »
What scan tool do you use for the car?
If it's some kind of android app and not VIDA,it can't be trusted.
In what shape is flexi pipe between exhaust manifold and cat?
If it's leaking,o2 sensors will report fault.
Also ...any exhaust leak in between exhaust manifold up to rear o2 will report fault and o2 sensors will not doing their job.
From '99 these cars use Denso management.
Is replacement o2 also Denso?
Bosch will not work on '99 and after.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
fszczesniak
Unfortunately it's not Vida, don't have access to that. I use obd fusion with elm Bluetooth adapter. Exhaust is to be smoke tested, because visually everything looks fine. Yes, it's a Denso sensor, OEM.
fszczesniak
What is the actual way to test if lambda is getting enough voltage? I was thinking that you purely turn the ignition on, probe the signal plus (blue) when lambda connected, check voltage on the multimeter between signal + and battery negative... shows only 3,8V! tried also the same procedure on S2 sensor and there was nothing
Has thanked: 1610 times
Been thanked: 4068 times
Its a heated OXS so there are two circuits to check - both the heater circuit and the sensor circuit.
fszczesniak
Yep, 4 wires (black black - heating, white ground, blue signal +). Checked heating circuit, 2 ohms, perfectly healthy (it's new after all). How do I check the signal circuit? What to probe and how?
