Hi - Think my catalytic converter needs to be replaced on my 03 v70 non-turbo automatic(B5244S,176k miles). CEL isn’t lit, but noticed a rattle during acceleration and clunk when the car turns off. Found a rubber mallet and lightly banged the cat; noticed the same rattle.
Anyway, any recommendations for an aftermarket catalytic converter? Not sure I want to pay $1400 for a genuine Volvo cat.
03 v70 non-turbo catalytic converter
- Biggertuna
- Year and Model: 2014 S60 T5
- Has thanked: 12 times
- RickHaleParker
- Been thanked: 958 times
You can get a direct fit MagnaFlow for V70s with naturally aspirated engines for under $500.00. MagnaFlow part number 51660.
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
are there any performance symptoms apart from the noise?...the exhaust has a joint about half way, it would be easy to get one from your local junkyard.
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
- Biggertuna
Yes - I've noticed a drop in fuel economy. It's also is a bit sluggish on acceleration.darrylrobert wrote: ↑30 Mar 2020, 04:43 are there any performance symptoms apart from the noise?...the exhaust has a joint about half way, it would be easy to get one from your local junkyard.
- RickHaleParker
Not here in the United States where the OP and I are. It is illegal to sell a used catalytic converter with it being tested and re-certified. Nobody does it here because it is too cost prohibitive.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
There are several other things to check before suspecting the catalytic converter. See the heat shield right above the exhaust manifold - behind the engine, it breaks at the securing bolts and starts rattling. The rest of the exhaust also has several aluminum heat shields that break at the securing bolts and will rattle - difficult to fix and expensive new from Volvo. The clunk when switching the engine off could be several things such as broken front or rear muffler brackets, engine mounts, etc.
- SuperHerman
- Been thanked: 207 times
Before spending any money you have to eliminate other causes. Heat shields are known noise makers as well as failed exhaust suspension parts. What you describe could be either or both of these. With prudence I would position yourself safely to see the exhaust system and have some one turn off the car and watch for movement - where is the clunk. oragex is spot on here.
You can pull the O2 sensor and using a mirror and flash light examine the condition of the honeycomb cat structure for broken parts and breaks. Performance issues, if cat related, would be a clogged up cat - you would also be able to see this.
On my old XC70 I installed an Eastern Cat and had 30k trouble free miles before I sold the car. I assume it is still going strong. It was a plug and play solution. Installation was very straight forward and fit was spot on.
- darrylrobert
interesting, i didnt know that. not here i just checked gumtree is full of used cat convertersRickHaleParker wrote: ↑30 Mar 2020, 06:44Not here in the United States where the OP and I are. It is illegal to sell a used catalytic converter with it being tested and re-certified. Nobody does it here because it is too cost prohibitive.
- June
- Has thanked: 523 times
- Been thanked: 261 times
SuperHerman wrote: ↑30 Mar 2020, 14:28 oragex is spot on here.
Absolutely!
If the honeycomb is rattling, as the chunks move they can cause a intermittent or constant blockage. I experienced many busted honeycombs from being submerged in water hot. Initially the chunks are big, as they rattle around small pieces break loose clogging the passages in remaining honeycom as well as bigger chunks can turn sideways then rattle back around causing intermittent blockages. I have looked at all converters removed from those cars. How it breaks, and the length of time driven that way seems to be the variable from what I observed. Eventually the car will pass it out the tailpipe. One of them came off empty. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- Biggertuna
Thanks for all the suggestions. Been reading that the rear O2 sensor is a pain to remove. Any recommendations on how to remove?
- 4407 Views
Last post by MadeInJapan
- 581 Views
Last post by lummert
