Electrical issues
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
CaptainWeenieWagon
Year and Model: 2004 V70
Has thanked: 2 times
Electrical issues
Post by CaptainWeenieWagon »
Hi!
So I had a question regarding this 2004 Volvo V70.
When purchased it had a check stop light everytime I hit the brakes. The side bulbs were not working and then replaced. This did not stop the message but the lights worked. Maybe I missed a clear the message step? Recently after a trip to the meat market for essentials the brake lights remain on. I have checked all fuses and checked the little plastic piece at the pedal and unplugged the unit underneath and the lights remained on. I'm guessing a relay maybe? Anyway, I'm looking for a diagram for the rear compartment if anyone could point me in that direction? Also, but maybe something separate the driver side headlight was replaced same as the brake lights and it has since blown. Thank you for your time and knowledge.
PainterPaul
Year and Model: 2004 S60 R
Post by PainterPaul »
Hi
I’ve got a 2004 S60 with a similar issue.
Stop Brake light message and brake lights don’t work when you step on the pedal.
Mechanics gotten frustrated and seeing if bleeding the brakes helps.
Have you solved your problem yet?
PainterPaul
Stop Brake light message.
There’s power to the relay. He’s checked all the fuses and changes the bulbs.
And the 3rd brake light comes on when you hit the pedal.
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
Not sure where the side brake lights are?..are you referring to the red led side marker lights on later models?
Fairly sure the bottom incandescent brake/stop lights are very basic electronics, there is a switch ontop of the pedal, wires to the back lights via a fuse and shunt resistor .Third brake light is connected to a seperate curcuit.
third brake light working, switch is okay, look at shunt,wires damaged fuses, relay (not sure there is one)
As for the check light, there are no codes that need to be cleared.
If you unplugged the switch and the lights remain on, that would drain your battery real quick?..i would start checking wires for shorts..good luck
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
CaptainWeenieWagon
Oh yes. So my problem was that some dillhole spliced the spoiler brake line into the main and there was a lot of other splicing going on up front lol.
My brakes wouldn't go off. Your brake lights won't come on? If you have checked all fuses I would replace the brake stop sensor or maybe even the little boot needs replacing or adjusting. I hope this helps!
PainterPaul
Do you have a photo or YouTube of the brake stop sensor or the little boot that I can replace ?
CaptainWeenieWagon
Located under the steering wheel and connected with a wire harness. I hope this helps. Search: brake stop switch for more videos.
PainterPaul
So you think this is a possibility instead of the REM being bad?
PainterPaul
just replaced the REM.
Same message
