V70 T to R Engine Swap?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
flytieoc
Year and Model: 2005 V70T
Has thanked: 2 times
Post by flytieoc »
My wife's daily, a beloved 2005 V70 turbo finally crapped out. It's been burning oil for some time and it is now running about four cylinders. We love the car and the performance. Going to swap in a used motor with lower miles as they are cheap and readily available. Found some R series engines at reasonable pricing.
Can I swap in the R for the T and use the auto trans axle as a direct swap, without much monkey business?
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
You need to be more specific.
flytieoc
Post by flytieoc »
Is the 52 vin R series engine from an auto trans car a direct plug and play into a 59 vin Turbo engine with an auto trans?
No changes. Bolt in the motor, plug in the wiring harnesses and computers and plumb in the cooling exhaust.
Is this that simple or are there modifications to the host car that need to be made?
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I think the short answer is no. You will need computer programming and more.
Has thanked: 1507 times
Been thanked: 3823 times
Stand by for input from “ Volvo Swap Specialist “ RHP
RickHaleParker
flytieoc wrote: 21 Apr 2020, 09:14 Is the 52 vin R series engine from an auto trans car a direct plug and play into a 59 vin Turbo engine with an auto trans?
For just a repair. There are better choices then a B5254T4 (52 R). Without software and turbo swap, the B5254T4 would have less power the the B2524T2 (59).
I would consider swaping the B2524T2 RN with a B2524T3 (68) RNC engine. Forged Crank. Stronger rods, graphite coated Silicon-Aluminum alloy pistons, better coolant circulation then a RN block. Both have the same Bore, stroke and compression ratio. You would need to use a RNC intake manifold. Some of the RNC engines have the front motor mount higher up but the bolt holes for the RN style front motor mount are still there on the RNC block.
