Strange brake issues
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Yaworski
Year and Model: 2002 S60
Has thanked: 5 times
Been thanked: 3 times
Post by Yaworski »
It all started off with me thinking that my transmission was being wonky but I found out that wasn't the case. The right front brake was grabbing and not releasing.
I took it to my mechanic and he said that the right front rotor showed signs of overheating. So he replaced the rotors and the flexible brake lines.
Then he tried doing a brake flush and no fluid was coming out of the left front caliper. So he disconnected the line at the ABS and had fluid coming out of the right side's port but not the left. He replaced the ABS unit.
So far he's replaced
  • Flexible brake lines
    Rotors
    Both front calipers
    Left rear caliper
    Master cylinder
    ABS box
Sounds like all problems should have gone away, right? Nope.
The car still pulls strongly to the right.
Any thoughts?
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Do you mean it pulls without braking ? More when braking ? Did he verify fluid comes out with the new parts ?
Yaworski
Post by Yaworski »
oragex wrote: 13 May 2020, 16:18 Do you mean it pulls without braking ?
It pulls when braking.
As far as I know, he verified the fluid flow at each step of the game.
oragex
Post by oragex »
How are the bushings on the control arms ? Can check the small one with vertical bolt by lifting the wheel. Also possible to have a bad subframe bushing if the car has many miles (over 200K or so)
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
What happens when you lift all four wheels off the ground and spin each wheel?
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
I had a control arm that did that. Brand was ScanTech if I remember right. Bushing was so soft that the wheel turned outwards when brakes were applied.
BMW 540i 2002
S70 Base 2000
oragex
Post by oragex »
kallekula wrote: 16 May 2020, 09:16 I had a control arm that did that. Brand was ScanTech if I remember right. Bushing was so soft that the wheel turned outwards when brakes were applied.
ScamTech is now called ProParts Sweden (or Professional Parts Sweden) and it's being sold on every web store, including Fcpeuro The company CEO must have good imagination how to choose company names. When he will change the name again to make customers forget about how bad it is, he will surely call it Best Parts Ever or something :lol:
kallekula
Post by kallekula »
oragex wrote: 16 May 2020, 15:38
Im a bit surprised to hear that FCP sells them. My belief was that they sold quality parts?
BMW 540i 2002
S70 Base 2000
