volvo 245 temperature sensor (s)
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
goateemagician
Year and Model: 1984 245
Post by goateemagician »
hello all, I have a 1984 Volvo 245 with the b23f redblock and a Chrysler ignition control unit. I have an issue with wiring, the second temperature sensor (closer to the firewall) is not connected to anything, where is it supposed to connect? I have the one to the dash, so I know this is the important one, I have no clue which port in the ECU or ICU or anything else, the manual I have does not seem to have the answer either. Thank you
Year and Model: 2001 V70
Has thanked: 928 times
Been thanked: 1002 times
Post by volvolugnut »
My manual has wiring diagram that shows there should be a blue wire to connect to the computer system for engine temperature. The wire should end up at port 2 of the ECM. The dash gauge has a separate temperature sensor.
If you need more detail, I can look at my '83 245 with same systems.
