Hello All,
Recently I bought C70 T5 1998 (320k km) and went to a mechanic to change the fluids and the spark plugs. When he removed the engine cover I saw the hole which was sealed with some black material (a little bit soft when engine is hot). As I saw on photos of other T5 engines this hole should be free. Does anyone know what this closed hole can cause and why someone did this?
By the way, PCV system is clogged here (glove test was failed) and I plan to change it. I want to know, do I need to remove upper half of cylinder head to clean this black staff?
What is this hole for? - '98 C70 T5 Topic is solved
- mashinalens
- Year and Model: C70 T5 1998, Coupe
- RickHaleParker
- Been thanked: 979 times
Optional location for a PCV breather hose. Like the optional location for the oil filler.
If it is not leaking leave it alone. If you want it to look better cut it off flat.
As for why somebody would do that. We have seen this one time before and nobody has a clue.
Active
Past
Past
- Been thanked: 4068 times
I think tourist imports came with the henway option that mounted there
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 63 times
- Been thanked: 81 times
About three pounds.abscate wrote: 18 May 2020, 07:27 I think tourist imports came with the henway option that mounted there
All U.S. market models.
All running and on the road.
- mashinalens
But this black thing is making me crazy. I think previous owner thought that oil was dripping from it and seal it.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
isn't that the glory hole?
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- mashinalens
- 3416 Views
Last post by FLXC90
- 563 Views
Last post by Ozark Lee
- 1234 Views
Last post by Ou2mame
- 1126 Views
Last post by crisnumbertwo
- 15 Replies
- 5184 Views
Last post by RussB
