Inner tire wear from rear toe bars?
Cookie-the-Swede
Year and Model: 2003 S60 2.5T AWD
Has thanked: 1 time
Been thanked: 4 times
Post by Cookie-the-Swede »
Hello all,
So I'm seeing abnormal wear on the inside of all of my tires. I rotate my tires every oil change so the wear is fairly even across all four tires but I suspect that it's due to to the lack of adjustment in the stock rear toe bars.
I'm also seeing that the camber is noticeable in the rear wheels. I have not lowered the car's suspension at all.
Do you think that it is the rear toe bars wearing my tires? Or is it new camber bushings? Or both?
Thanks in advance.
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
One of my XC’s is doing this as well. So far, I’ve determined that one of the stay arms (9200217) is bent slightly, and also the trailing arm bushings are terribly worn (31277893). I did a little instructional on replacing trailing arm bushings a little while ago. There’s oodles of bushings in the rear that could be contributing. Also if your rear springs are sagged that would contribute also.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
