Ac Problem
Anaivi0713
- Year and Model: 2007 xc90 3.2 awd
Ac Problem
I replace the AC compressor, the expantion valve and the drier. After all the process of refrigerant etc. It worked for a few minutes then all the lines when from really cold to hot. What should I do?? What else can it be?
- June
- Has thanked: 523 times
- Been thanked: 261 times
Check cooling fans/ clean condenser coils. Otherwise we need to know what the high and low refrigerant pressure is running to be more helpful. You did leave it at vacuum for five minutes at least once vacuum pump was off and closed to be sure no big leaks? June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
Anaivi0713
Vacuum was done right. Coils are clean and fans are running...
jimmy57
- Been thanked: 320 times
The compressor is variable displacement. The evaporator in the case has a temp probe that reports air temp about 1 inch from evaporator. The climate control module gets this signal and then sends a signal to engine control module to request high, medium, or low compresor functioning. The engine control module pulses a solenoid inserted into side of compressor to control the compressor. The evaporator temp probe can cause poor cooling and if that is it the evaporator temp read out from the climate module will be wrong. On a 34C day before the car is run the climate control evap temp would be 34-38C. if it reports a much cooler temp like 13C then the compressor will not be commanded to higher output and it ill not cool well when everything else is working as it should. Another failure can be the solenoid inserted into compressor sticking. In that case the evaporator temp will be reported correctly and if you read a/c control signal from the ECM it wil be 75-90% but the low side and high pressure will be 95 and 115 respectively as the compressor will barely be moving refrigerant. VIDA or a scan tool that reads Volvo modules will have to be used.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Not necessarily related to the issue, but I found this interesting AC troubleshooting guide https://www.buyautoparts.com/howto/ac-p ... adings.htm
- 1325 Views
- 12 Replies
- 2992 Views
Last post by Jaguar xjs
