turning off the oil change light Topic is solved
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
azureblue
Year and Model: 2014 S60 T5
Has thanked: 16 times
Been thanked: 8 times
Post by azureblue »
2001 V70 T5
I know I know "Just google it". "read the archives."
I have found no less than 4 ways to do it. And none work. I followed every one to the letter.
285 1 1 007071
Ideas? Anybody got the real procedure? Besides VIDA of course?
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
What do you mean by oil change light ? The red oil lamp light is a warning light for low engine oil pressure - engine must not be started or driven. Or you rather mean the 'Time for Regular Maintenance' message ?
93SCMax
Year and Model: 2001 V70 T5 mt
Has thanked: 36 times
Been thanked: 44 times
Post by 93SCMax »
For my 2001 V70 T5, the following works after an oil change (when service lamp on):
1) Press and hold odometer reset button/stalk.
2) Turn ignition key to run (not to start).
3) After Service Reminder Lamp flashes three plus times, release odometer stalk.
4) Turn ignition key to off.
5) Start car and confirm no Service Reminder Lamp on.
Sometimes it's finicky and I have to do it a few times...damn old car.
Good luck.
azureblue
Post by azureblue »
yes. the service light. the oil change light. Not the low on oil light. The oil change light that comes on every 3K miles. I wanted to reset it after I did my oil change....
Here is what doesn't work:
1 - with ignition off, press and hold the trip odo "reset" button, and turn ignition to I
2 - Hold button for 10 seconds until light flashes
3 - A tone will sound and the light will go off
4 - turn off ignition
1 - Same until step 2 - change to: turn key to II When trip odo resets to 0 the orange warn light in the center will flash
2 - release trip odo button.
3 - turn key to off
1 - press and hold odo reset , turn key to "run" (I guess they mean III)
2 - hold button for 10 seconds, release button, light will flash
3 - a tone will be heard then service light will go off
4 - turn off ignition key
1 - get in car, shut the door
2 - put key in ignition, turn key to I
3 - Push in odo reset and hold it in.
4 - turn key to II
5 - wait a few seconds, then the service light will blink
6 - let go of odo reset button and start car
7 - run car for a few minutes then turn off car.
I have gotten the tone, i have never gotten the triangle warning light, the service / oil light has blinked every time..
And the sucker is still on..
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
azureblue
Post by azureblue »
"For my 2001 V70 T5, the following works after an oil change (when service lamp on):
5) Start car and confirm no Service Reminder Lamp on."
Ok, I'll try this one :-). If this doesn't work, I will resort to gris gris and maybe burning a candle or two
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
azureblue
Post by azureblue »
azureblue wrote: 29 May 2020, 14:42 "For my 2001 V70 T5, the following works after an oil change (when service lamp on):
Nope this one doesn't work either. :)
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
chris11211
Year and Model: 2006 s60 2.5T
Has thanked: 7 times
Been thanked: 29 times
Post by chris11211 »
gonna have to get a obd ii reader from amazon to erase it
azureblue
Post by azureblue »
Yeah it looks like it - but what makes my car so different? I mean, if all these ways won't kill the light then what profile for my car for VIDA will work?
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
Year and Model: 2004 V70 2.5T
Been thanked: 472 times
Post by cn90 »
Worst-case scenario...cut a square piece of black electrical tape and cover the light.
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 80 times
Been thanked: 175 times
Post by - Pete - »
You can do it in ViDA, but what’s always worked for me is
  • KP1 (key position 1)
  • Press & hold odometer reset button
  • While still holding odo button, turn to KP2
  • Continue holding reset button until yellow triangle (!) flashes
  • Release reset button
I can’t recall ever having an audible alert signifying it’s been cleared. Might be a feature on newer cars?
https://www.ipdusa.com/blogs/103/howto- ... 009-volvos
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
