inside a failed angle gear box
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
My used replacement angle gear has a very small leak from i believe the adjusting "castle nut" oring. i wont be fixing it becaause i am not keen to disturb the setting that nut has. I took apart my damaged angle gear curious to see where it could be leaking from and how it works.
you can see the worn splines on the input shaft, the collar was equally worn causing it to spin freely. Brown stuff looks like corrosion but its actually grease.
failed angle gear 1
failed angle gear 1
failed angle gear 2
failed angle gear 2
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
That doesn't look too bad. You can try to wire brush and clean up the splines and then plug it into a collar to see what kind of play, if any you have. The collar is made of a softer metal than the gear splines so that it survives, fairly typical.
I had one once where the actual bevel inside the housing was toast.
Re the lock nut, I believe the work around is to closely and precisely mark the nut and the case, then count turns. Return the preload to the original marks. That is what I did and didn't have any issues. I believe there is a Volvo TSB on resealing the cases which should have more information for you.
