91 240 output shaft seal removal Topic is solved
e777
Year and Model: 1990 740
Has thanked: 11 times
Post by e777 »
Hello,
So, not so long ago, I noticed tranny fluid leaking from the output shaft area. I removed the extension housing, pressed in a new bushing and new output shaft seal and all was well for some weeks. Then, I noticed a slow drip coming from the output shaft seal.
Therefore, I am now having to do re-do repair and I really hope to not have to take the extension housing off again to do it.
However, it seems tricky to remove the seal by leaving the housing in place....
Any tips for doing this without removing the housing? Or is that just a bad idea?
Thanks!
Wagons:
93 940
91 240
90 740
86 740
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
However you gain access to the seal, use a quality seal and be careful not to cut the lip on splines or edges. Use tape over splines to protect the seal. Use a seal driver to assure you do not damage the seal metal housing. If there is a gaiter spring inside the seal, do not damage it. Install in the correct direction - lip to oil side.
I think you have to remove the extension housing to replace the seal. Others may have another way.
e777
Post by e777 »
Your advice is much appreciated.
Question: when you say "lip to oil side," do you mean that the surface shown in the attached image will be driven *into* the housing, as opposed to facing outward?
output shaft seal.JPG (26.9 KiB) Viewed 1355 times
Wagons:
93 940
91 240
90 740
86 740
Image below shows the cross section of a typical oil seal. Yours may be different. The round thing in the center is the gaiter spring that holds the oil seal in firm contact to the shaft. This side should go toward the oil (inside of housing). The smaller lip on the left side is the dirt shield. It goes to the dirty side of the housing.
I can't see the cross section clearly, but I think the top side is the dirty side (outside of housing). If installed opposite, it will likely leak.
oil seal section.JPG (13.61 KiB) Viewed 1332 times
e777
Post by e777 »
Thanks! That's what I did the first time and will do again the second time.
Wagons:
93 940
91 240
90 740
86 740
