Question re: 2000 V70r differential
diplomaticm3
Year and Model: 2004 xc70
Has thanked: 1 time
Post by diplomaticm3 »
Is the rear diff for a 2000 V70r interchangeable with any other model? Or is it unique as hell like every other powertrain element?
Thanks in advance
Has thanked: 2205 times
Been thanked: 1852 times
You really need someone to look up the part number for a V70R diff and then compare to the V/S70 AWD and the V70XC
Of those I believe the 'R' is the only car with a 5 speed auto. The others had a 4 speed auto. Not sure if that would affect the read diff ratios. We need someone with access to Vida to check. My PC with Vida is down for now so can't check for you. Strangely I have a spare in the garage from a 2000 V70R.
Has thanked: 1610 times
Been thanked: 4069 times
diplomaticm3 wrote: 25 Jun 2020, 19:52 Is the rear diff for a 2000 V70r interchangeable with any other model? Or is it unique as hell like every other powertrain element?
Thanks in advance
Put the VINS into the Volvo web store parts engine and pull up the sub assemblies
Read the fine print carefully on the parts lists.
diplomaticm3
Has thanked: 1 time
See that’s the problem, the Volvo parts site is a mess. I get the same part # when I search a 98 and a 2000 v70r.
And yes it would make sense that the rear diff might be different with different transmissions.
