Seatbelt service or replace xc70
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
The rear seat belt isnt retracting as well as i think it should and looks it has been jammed in the door a few times.
The fix is to wind the coil a few extra turns, but taking the seat apart is a major pain.
An inside out zipper ..
Rear seat teardown
Rear seat teardown
The actual seatbelt recoil hidden inside the seat can be unbolted and serviced.
Left side is the annoying rollover lock, right side is the spring loaded recoil.
Belt teardown
Belt teardown
The seat latch come off with two bolts. Turned out i didnt need to remove this.
Seat latch
Seat latch
The plastic seat release, i can see why this breaks easy. Theres a plastic clip under the belt that needs to be pried up and off before removing this panel.
Rear seat release button
[attachment
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
br0dy519
Year and Model: 2004 XC70
Has thanked: 126 times
Been thanked: 116 times
Post by br0dy519 »
Thanks for posting. I'm actually looking at doing this myself. My rear passenger side belt isn't retracting very well. Just curious do we consider this a safety issue? Looking at your post above doesn't make me all that ambitious to do the job. Is there any stitching required or is it all zipper-based work?
04s60 2.4
04xc70 2.5t
darrylrobert
If the seatbelt sits loose on the passenger then yes its a safety issue.
There is no stitching to be removed, start from the bottom/ underneth then the side zipper and all will unfold and make sense. The recoil spring is quite tricky. theres a round aluminuim ring/key that is the trick to winding it up placing back onto the seatbelt. I used a small vice-grips to hold the key while turning the case.NOTE: it took me several attempt and alot of swearing to re-tension the spring and im not sure its working any better.
br0dy519
Post by br0dy519 »
darrylrobert wrote: 14 Jul 2020, 03:43 If the seatbelt sits loose on the passenger then yes its a safety issue.
Oh man... that stinks. I'm thinking it might be better to grab a belt from a junk yard then? I remember having to fiddle with the tensioners when I installed my 3rd row seat in xc70 and let the belt retract "too far" into the reel. Then I had to disassemble like you and retension the spring and curse and swear about it for hours. I've found the website SafetyRestore as well.. I'm wondering if they have the capability to fix Volvo belts like this.
EDIT: Looks like that company can actually repair our belts. Something I'm willing to pay $80 USD plus shipping premium to do so that I don't have to muddle around with the damn spring again. Question regarding removal of the belt: would it be possible to remove just the belt reel mechanism without removing that explosive cylinder for shipping? Apologies if it's a dumb question I've just never really worked with this sort of belt before. Answer: The reel/pretensioner are a complete single-stage assembly.
04s60 2.4
04xc70 2.5t
