turbo comp chart, core interchangeable? 16t vs 18t vs 19t Topic is solved
CIK7
Year and Model: 2026 Sportrailer GLT
Has thanked: 350 times
Been thanked: 108 times
Post by CIK7 »
On my last thread, we discussed the t5 vs r engines. i understand the turbo does make a difference. I remember reading somewhere the 18t is plug and play and easier to deal with than the 19t. I was considering buying the 2.3 from a t5 and swapping the core from 16t to 18t or 19t. can someone please help me? the turbo compare (see link below) is a bit confusing to me and newed help figuring out if i can buy a 18t core or 19t core to put n my 16t housing. Chart shows 16t/18t/19t as Sb. What is that?
https://www-matthewsvolvosite-com.cdn.a ... rgers.html
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
Has thanked: 1611 times
Been thanked: 4071 times
Check with bdub , who is In. The middle of a 19T turbo upgrade on his old car..thread in December
CIK7
Post by CIK7 »
abscate wrote: 21 Jul 2020, 09:46 Check with bdub , who is In. The middle of a 19T turbo upgrade on his old car..thread in December
did he change his username? bdub didnt come up in member search
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2861 times
Been thanked: 1332 times
Post by matthew1 »
Also -> Amazon link
CIK7
Post by CIK7 »
oh yeah i recognize that name for sure! Thank you!
Has thanked: 2207 times
Been thanked: 1852 times
I have a 2000 V70R with the 19T turbo. Some will say bigger is better and some cases that may be. However, the 19T is a big turbo and it is slow to respond compared to the smaller 16T and even the 18T. It may give more power higher up in the rev range, but for a daily driver it is a bit of a slug.
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
CIK7, stick with the 13g until you do a manual swap, or some 13" wheels and stance that mother. Otherwise, you'll get gapped by Grannies in Toyota Avalons!
Current Volvos:
CIK7
Post by CIK7 »
FLXC90 wrote: 21 Jul 2020, 15:01 CIK7, stick with the 13g until you do a manual swap, or some 13" wheels and stance that mother. Otherwise, you'll get gapped by Grannies in Toyota Avalons!
lol im flaking on the manual swap. the 13g engine is dead. right now im focused on a new engine with fresh parts. im thinking about buying b523t3 engine, replacing 16t with 18t, swapping the blue injectors for white injectors. What ECU would I need with this setup? T5 or R? I dont want to stance it. And i have the V70 T5 wheels on there. Awesome tires too. but with the turbo, which parts do i swap to go from 16t to 18t?
CIK7
Post by CIK7 »
i updated the thread title and post a lil.
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
CIK7 wrote: 21 Jul 2020, 16:49 lol im flaking on the manual swap. the 13g engine is dead. right now im focused on a new engine with fresh parts. im thinking about buying b523t3 engine, replacing 16t with 18t, swapping the blue injectors for white injectors. What ECU would I need with this setup? T5 or R? I dont want to stance it. And i have the V70 T5 wheels on there. Awesome tires too. but with the turbo, which parts do i swap to go from 16t to 18t?
The B5234T3 is just a basic 2.3 HPT engine. What year are you getting it from? 99-04 B5234T3 has exVVT. (You can just leave it unplugged, if it has it)
The white and blue injectors are basically the same, no need to swap them in this application.
If you're going to use the 18T and you're AWD you'll probably want a '97 V70R AWD ECU (last 3 digits of -455).
