You're in a ship traveling away from Earth at 50% the speed of light, relative to Earth.
You turn on a bright light pointing at Earth.
How long does the light take to reach Earth? Say you're one light minute away from Earth, traveling at a constant velocity, for the sake of argument.
I don't know the answer, I'm asking.
I know the light will appear red-shifted when viewed from Earth, but will it take twice as long because the ship is moving .5 speed of light? Or is C an absolute (IIRC, Einstein said this is the case)?
Relativity question
Forum rules
- Has thanked: 2656 times
- Been thanked: 1248 times
Relativity question
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 115 times
- Been thanked: 185 times
The short answer is the speed of light in a Vacuum is constant.
The speed limit isn't affected by velocity of the source.
If you really want to brake your brain then you need to ask what happens if a particle exceeds the speed of light (think particle accelerator)
For this second example you get Braking Radiation (Bremsstrahlung to be exact)
https://en.wikipedia.org/wiki/Bremsstrahlung
https://en.wikipedia.org/wiki/Synchrotron_light_source
Thanks Paul. Very interesting. It's hard to wrap my mind around this constant. i.e.: that you could be traveling so fast away from something yet that speed won't affect the speed of light it's emitting. I enjoy thinking about how this stuff happens whether I wrap my mind around it or not
I've been reading a lot of Alastair Reynolds, who writes (mostly) hard science fiction, and these concepts come up frequently in his books.
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
Everything in special relativity is tied together by all parties observing light traveling at precisely c, no matter the source and target. All the weird space travel effects you read about in sci-fi - such as the time dilation effect that plays such an important role in the Ender's Game books - follow from this.
It is hard to wrap one's mind around. At the moment one understands it one asks why this seemed so hard before (at least for special relativity, which you can understand conceptually without doing too much math). If you can find a copy of TM Helliwell's Special Relativity, which seems to be out of print now, it's a great intro that's easy to follow and really helps you build an intuition for it. I've completely forgotten SR, but I remember that book being the only reason I was able to pass the class. If only I could find my copy.
- Has thanked: 1506 times
- Been thanked: 3822 times
If it’s a p80, light is stopped p0455 code
- gnalan
- Year and Model: 2001 S60
- Has thanked: 557 times
- Been thanked: 135 times
Mind if I tweak your question a bit?
You're in a Volvo driving on the freeway at 75mph. You have 150 miles left to drive, but only 15 minutes of daylight left before it's pitch black out.
If you reach over and flip your headlight switch on do your headlights come on?
- Has thanked: 928 times
- Been thanked: 1002 times
When you drive 75 mph in lesser cars, you may not see the light from your headlights because you have over driven the light beam. However, if your Volvo headlights do provide light when you turn them on, your headlight wiring may have crumbled.
volvolugnuty
volvolugnuty
- RickHaleParker
- Been thanked: 958 times
That is why a blue or red shift does happens. The ship's velocity adds or subtracts space not velocity to the wave. That is why the word length is in the term Wave Length.
IF the ship velocity did effected the speed of light there would be no shift because the wave would occupy the same length of space it did in the ship, therefore no change in wave length.
