I have a gas leak where the sending unit is on the driver's side. I'm not sure if it's the seal, the sending unit, or the plastic hold down ring. It was leaking when I bought the car, and I went ahead and replaced the fuel pump while I was trying to fix the gas leak. Now the leak is worse than it was before I swapped fuel pump.
I have 3 different seals, and they're all the same size, yet when I installed the seal it seemed like it was too big to fit into the groove and after filling the tank I could see the gas leaking past the sending unit.
Do you know if there are other size o-rings, or maybe something I overlooked when I installed it? Maybe a tip/trick to get the o-ring to fit into the groove, or a part number for one that will fit and stop the leak?
gas leak from around left side sending unit Topic is solved
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
The top of the plastic sending unit is the usual suspect, there was a recall many yrs ago.gnalan wrote: 09 Aug 2020, 14:53 I have a gas leak where the sending unit is on the driver's side. I'm not sure if it's the seal, the sending unit, or the plastic hold down ring. It was leaking when I bought the car, and I went ahead and replaced the fuel pump while I was trying to fix the gas leak. Now the leak is worse than it was before I swapped fuel pump.
I fixed mine with gas proof jb weld after cleaning it with brake clean spray.
No need to remove it.
Allow to cure 24 hrs.
- gnalan
- Year and Model: 2001 S60
- Has thanked: 557 times
- Been thanked: 135 times
The fuel pump is brand new, and isn't what's leaking. It's the sending unit on the left side, the one the fuel line connects to for fuel pickup, that's leaking.jonesg wrote: 10 Aug 2020, 07:44 The top of the plastic sending unit is the usual suspect, there was a recall many yrs ago.
- Has thanked: 987 times
- Been thanked: 1075 times
I think you will have to remove the sender side plug again and look it over. If the seal is torn or folded over it will be obvious that is the problem. Otherwise post close up photos for everyone.
- gnalan
From underneath the car the tank looks plastic, but when I replaced the fuel pump it looked like metal from the top (judging by the groove the seal went into).
Do I have a plastic or a metal tank? I thought the metal tanks only came in the AWD models, but I could be wrong.
If the tank is metal and not plastic, will the fuel pump I installed for a plastic tank cause me any problems? It's a brand new Bosch pump, and I don't think I can return it to RockAuto, after it being used, to replace if for one for a plastic tank.
Does a magnet stick to tank?
- gnalan
I didn't even think about using a magnet. I'll check and see if it's magnetic, and post back in a few minutes.
- gnalan
Plastic, thankfully. I was worried I'd need to change the fuel pump to one for a metal tank.
My telescopic magnet, mostly used to pick up bolts/tools that I drop, stuck to the undercarriage, but I tried all over the bottom of the tank and nothing.
I don't suppose the bottom could be plastic and the top metal? (Stupid question, but I haven't had much sleep or I'd have thought to use a magnet, maybe.)
All plastic, just like mine. It will never rust inside or out.
- 992 Views
Last post by mrmail
- 1574 Views
Last post by 5ft24
- 677 Views
Last post by Carbon15
- 1075 Views
Last post by beigg
- 3303 Views
Last post by RickHaleParker
