1998 Volvo V70-R for sale
Mriv1998
Year and Model: 1998 V70 R
Post by Mriv1998 »
Selling my ‘98 V70-R
Absolutely love this car but am parting ways with it because I purchased something a bit newer and can’t afford both. In my time owning it, I did the usual maintenance to be performed on a p80 and have all the service receipts as proof.
The car currently has 156k miles and is not being driven except for around the block.
Maintenance Done:
Timing belt, water pump (all parts from ipd) at around 150k
New front CV axels, lower control arms, inner/outer tie rods
Transmission, and AWD serviced
Spark plugs, cap, rotor, and wires
Whole PCV Breather job was done
New abs module
New crank position sensor
Had a vacuum line replaced
And a few other things plus regular maintenance.
Mods Done:
New Vibrant mufflers installed, car sounds great not loud at all, just right.
Only things that needs attention are the rough headliner and the Check Engine is on but it’s due to the SAS pump.This is an emissions thing and had no effect on performance, can either be replaced or deleted, I personally passed inspection without doing either because of the age of the car in NY state
Car will be sold with a fresh set of brakes and rotors as well as some small silicone hoses for the coolant reservoir, ,poly subframe bushings, and a replacement lock assembly for the front passenger door which I never got around to putting on.
Asking 2800 OBO
Shoot me a text at 631 215 5522 if interested
