2010 S80 Starter issue (I think)
Third generation Volvo V70 wagon and XC70, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
asap11
Year and Model: 2010
Post by asap11 »
Hi there,
So, my S80 has 157K miles on it and is lagging when I start it. I have to hold the start button down until it starts.It only takes a second but previously I'd just push the button quickly and it would start right up.
At first I thought it was the battery but there is no clicking and after a day or two of this the battery hasn't died or anything.
I'm almost certain the following is a coincidence, but I did take the car in to replace the rear rotors. When I dropped it off it wasn't happening and when I picked it up I noticed the delayed or lag in starting. I can't see how they could be related, but I thought I'd mention it.
Do you all think its the starter? I'll buy and replace it today if so.
Thank you!
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 115 times
Been thanked: 185 times
Post by pgill »
For my 2010 S80 I am still on the origional starter
For my 2008 LR2 (Same engine as the S80) I did replace the starter.
What's not clear from your explanation
Option 1 - you dock the key, press the brake, press the start button, nothing happens for 1 second then the starter engages
Option 2 - you dock the key, press the brake, press the start button, starter engages immediately but the engine required 2 seconds to start running
A new starter will only help with option 2
For my LR2 the new starter is noticeably faster, the higher speed results in the engine starting sooner.
I bought a Bosch starter and I am very happy with it.
Good luck
Paul
asap11
Post by asap11 »
The engine would turn over very quickly in the past. Now the engine doesn't turn over so fast. I just recorded a video to show what I mean.
I think it is the starter. The question is how long until it stops starting. Do I have tome to get a new one before losing the use of the car.
Thanks!
pgill
Post by pgill »
It does seem to respond to the docking of the key and the press of the star button.
It looks like you have option 2
A new starter is noticeably faster.
I can't predict how long you have.
When it stops working you are stuck at that location.
The good news is that it isn't hard to change at all.
If you can change you oil then you can change the starter
Good Luck
Paul
PS I was surprised by how much faster a new starter operates
If you want to read more about the starter here is a link
https://www.freel2.com/forum/topic29593.html
asap11
Post by asap11 »
Thank you very much for the quick reply. This just started happening about 2 days ago.
Do they normally get worse over time or suddenly die? Do you think I can get back and fourth to work and fix it this weekend or would you rush to get it done asap? I know there is no way to really know but what is normal?
Thank you again!
pgill
Post by pgill »
If you have someone that can pick you up then the risk is low.
I would risk it but its up to you.
My starter did fail suddenly
asap11
Post by asap11 »
Thank you!
