The Car it's not ready for Smog Text
Dimi2233
Year and Model: 1999 V70
Post by Dimi2233 »
Hello Forum
I have 1999 Volvo V70, I have to do Smog Text , I disconnected the Battery 2 Month ago The car it's not ready for a smog Text I have to Drive More. I drove more than 1000 mile the Car steal it's not ready.I drove systematic ,after every speed 50,60, 65, 70, 80,85, I stop for 2-3 minutes with the Engine running to reset the Computer
Somebody know what the next step to do .to bee the Car ready for smog Text.
David
Has thanked: 1610 times
Been thanked: 4068 times
You have to ...
Not exceed 60,mph
Keep,throttle between idle and 3/4
Keep ga stank filled between 1.4 and 3/4
Don’t use air conditioning
Drive for 2o minute following these, stop and idle for 3 minutes, then do this again
patcal
Year and Model: 1998 S70 GLT
Has thanked: 99 times
Been thanked: 10 times
Post by patcal »
Not sure where you are but when I bought my 98 S70 GLT the readiness monitors were not checked off. I am in Portland, OR. When I finally just went to try to get smoged they plugged in the OBDII & also tailpiped it. They said Volvos are very difficult to get the readiness set so they double check with the sniffer test. If it passes the sniffer, they pass the car. Sorry for being so long winded. Hope this helps.
Pat Callaghan Jr.
98 S70 GLT
Dimi2233
Post by Dimi2233 »
I know if they connected the Car to Sniffer the car pass the smog Test Chech this link
http://justsmogs.com/2014/07/volvo-obd- ... -monitors/
Technician can reset the Computer in Shop in 15 minutes They don't want to .
I will find the way to pass the smog Test
David
Dimi2233
Post by Dimi2233 »
abscate wrote: 01 Sep 2020, 17:51 You have to ...
Not exceed 60,mph
Hello Empty Nester
I try your suggestion twice do not do not Work, I took the Car in Desert 500 mile High temperature ,High speed do not Work
I took the Car for Smog check, ASM Emission Test : Pass,Funcial Test = Fail,He said don't know what wrong with Car No communication with Computer.
Pay $91.00 for Smog Check ,The Computer don't know what it's wrong with the CAR.
David
Any speed over 60 mph will stop the monitor Reset cycle.
1998v70xcbill
Year and Model: 1998v70xc
Been thanked: 3 times
Post by 1998v70xcbill »
search for "flywheel adaption procedure". Good Luck. I can be done.
Dimi2233
Post by Dimi2233 »
That it's my Problem I listen of Professionals, I reset the Monitors using Cruise Control on and I pass the Smog Text
David
slickdizzy
Year and Model: 1996 Volvo 854 R
Has thanked: 9 times
Been thanked: 15 times
Post by slickdizzy »
This is the only post I’ve ever found that THOROUGHLY covers getting a car through the P80 flywheel adaptation and monitor readiness from start to finish. Most posts seem to only address one or the other.
https://www.brickboard.com/AWD/volvo/14 ... ccess.html
The key is the flywheel adaptation, most people go blue in the face trying to get the monitors set while the flywheel adaptation isn’t complete (including yours truly at one point).
~Desmond (Current: 1996 854 R, Past: 1998 V70 GLT, 1997 855 R, 1988 744 Turbo, 1993 965)
Sufbug
Year and Model: 1998 V70
Has thanked: 2 times
Been thanked: 2 times
Post by Sufbug »
Dimi2233 wrote: 16 Sep 2020, 10:52 That it's my Problem I listen of Professionals, I reset the Monitors using Cruise Control on and I pass the Smog Text
David
Congrats. What speeds did you run at? And hahahahaha every document sys DONT use the cruise control... Good on ya!
1998 V70 wagon / 244,013 miles / purchased 9-25-2020
2016 Cadillac CTS4 / might be selling this
1979 trans am 400ci / 4 speed / t-tops / not selling this
