This seemed straightforward enough (famous last words). The two bolts on the passenger side came out without drama. However, both bolts on the driver’s side made it out a few turns before the captive nuts inside the floor stamping failed and the bolts started spinning free.
I don’t know if I’d call it “lucky” but at least with the passenger side bolts fully removed, I barely had enough room to slide the downpipe over and out from the exhaust tunnel.
Now I have to figure out what to do with one side of this crossmember flapping in the wind on half loose bolts. My understanding is that this part provides structural stiffening (the C70 convertible brace attaches in the rear where this plate is) so I definitely want to find a way to get this reattached.
I can cut the heads off of the existing, free spinning bolts easily enough, but then I still have two captive nuts bouncing around in there to deal with; and looking at the floor pan stamping, it does not appear these can be accessed from inside the car, it looks like they are sandwiched between layers of metal...I can’t see any way that I could extract the broken captive nuts without really hacking up the underbody stamping.
Has anyone dealt with this before that has any suggestions?
