Hi All,
I just picked up 2 XC-70s to replace my 2000 v70 and a worn-out 2006 Corolla. One is a 2004, the other is a 2006, both with 134k km (about 84k mi).
I am in the process of sorting out some issues, the first is that the 2004 needs a passenger side front spring seat. It makes a nasty noise on rough roads, and I can turn the top nut easily with a wrench. I plan to replace both sides at the same time since I don't want to pay for 2 alignments.
I know that I want the updated design, but I am wondering which is best. iPd makes some strong claims about theirs being better. FCP has Rein ones on sale now. I am curious to hear what people have used and how they have held up. Some sites claim that you should change the strut bearings at the same time.
I am also interested to hear what the job was like for those who have DIY experience replacing the seats. Is there a good tutorial here?
Thanks!
2004 XC-70 spring seats-- which ones?
Herb Goltz
- Year and Model: 04& 06 XC70, '12 s60
- Has thanked: 7 times
- Been thanked: 5 times
2012 s60 t5
2006 XC70
2004 XC70
2006 XC70
2004 XC70
- SuperHerman
- Been thanked: 207 times
Volvo replacements are preferred. The "upgrade" unit is the same as for an XC90 is what I understand. I have used Rein w/o issue, going on 30k miles - not sure if they are as good as Volvo branded as only time will tell.
As to the strut bearings, replace them if they are bad. I have not encountered a bad set on any of my Volvos to date, but like you I have read of people that have had failures.
As far as how the job is - it is basically like any strut change on any car. Remove strut, compress spring, remove offending parts and reverse. There are write ups and videos - look for strut, strut bearing, spring or spring seat - they are all the same process.
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
Ive replaced my upper spring seats with IPD reinforced ones because i wronly thought mine had broken, you do mean upper spring seat because there is also a lower spring seat. The upper seat was not the cause of the noise it was the "castle" nut had worked loose allowing the seat to move up/down over bumps making a noise, easily turning the top nut is also an indication of this as the whole shaft turn inside the shock absorber.As for the bearing check for a large amount of play.TIP tighten that "castle" nut really tight.
Im missing the lower seat on my springs, i havnt bothered because they look too easily damaged (waste of money) but i think without they cause a creaking noise sometimes.
Ive removed the struts so many times i can do it with my eyes closed but when you get an alignment they will/should check the camber but its good practice to measure the camber before removing the strut.
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
- 4702 Views
Last post by chumpden
- 9719 Views
Last post by RickHaleParker
- 132 Views
- 800 Views
Last post by Goupil
- 1056 Views
