Hi All:
My newly-acquired 2004 XC-70's resonator (the front muffler) has blown out. Has anyone found a good aftermarket one to have welded in? The car only has 134k km, so the pipes are in great shape, so I would rather go this route than a cat-back, which only seems to last 2-3 years on salty Canadian roads. I have a good muffler shop that usually does welding for me.
That said, I suspect the rear muffler won't be too far behind. Any tips on what to use there? I have had a bit of sticker shock looking at aftermarket direct fit systems...
Thanks!
2004 XC-70, aftermarket resonator replacement?
Herb Goltz
- Year and Model: 04& 06 XC70, '12 s60
- Has thanked: 7 times
- Been thanked: 5 times
2012 s60 t5
2006 XC70
2004 XC70
2006 XC70
2004 XC70
- SuperHerman
- Been thanked: 207 times
If I recall correctly I bought a Walker unit from Rockauto, just looked and it is under $50. Worked just fine for the 30k or so miles until I sold the car. Mounting was not an issue.
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
I put a Walker on mine from the Cat to the muffler 5 years ago, it was a near perfect fit and still in great shape on salty roads, I used a OEM muffler from the boneyard because I found a perfect one and the aftermarket muffler was over $300.
2003 XC 70 (sold)
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
My mechanic offered to weld in a piece of straight pipe for $75 CAD all in. I think JRL calls it his resonator mod or something, he’s very proud about it
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
With a section of pipe in there vs a resonator it really doesn’t change the loudness very much at all. These I5’s sound very nice with a little relief applied to the original exhaust system.
You’ll have a little deeper tone and a slight “pop” on decel, other than that, not much change at all.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
Herb Goltz
Thanks all! I went with a welded-in aftermarket resonator. My exhaust guy likes to preserve the original pipes as long as possible, as the replacement cat-back systems really don't last on salty Canadian roads...
2012 s60 t5
2006 XC70
2004 XC70
2006 XC70
2004 XC70
- 30 Replies
- 2370 Views
Last post by DavidE7
- 361 Views
Last post by rjS60Turbo
- 614 Views
Last post by SuperHerman
- 1743 Views
- 4074 Views
Last post by timmybdaddyof3
