2001 V70 NA AWD? -- Silver -- Schodack ( Albany) NY -- $500 runs
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
Posting for a friend in Schodack, NY area -- I am not the seller! I am giving the information I have as of my seeing the car last week as I couldn't buy it. Not enough room =(
Richard can be emailed directly at [email protected]
The good:
Underside of the car with exception of rear exhaust looks spotless
AWD intact?
New battery
Body has an exceptionally small amount of rust on the underbody. Has two spots on the body that are less than an inch that could likely use attention.
The bad:
Cylinder 3 misfire according to VIDA. Believe it just needs a coil based upon personal experience.
Needs a tire as front right is roasted on the inner side
Needs new seat skins (as does nearly every other car this old)
Sunroof could use a bit of work. Currently closed.
Other:
Car starts and runs - always a plus in our forum =)
Owner was told it needed a brake booster and will furnish one.
Car comes up to temp and doesn't appear to overheat
No visible coolant leaks.
No abnormal oil consumption.
Needs lighting control module plugged back in. Owner was trying to track down a dome light not turning off and unplugged it.
Pictures to follow... Possible updates too as I'm going to have the owner review it.
