C70 Propus hub sizes Question
diplomaticm3
Year and Model: 2004 xc70
Has thanked: 1 time
Post by diplomaticm3 »
Hi folks...I can’t find a confirmation on this so I figured I’d ask the experts.
Volvo Propus wheels...are they all 65.1 center bore / hub size? Including the 2001-04 models?
Just trying to confirm if any Propus / Propus C’s came in the ford hub size (63.4).
Thanks in advance.
slickdizzy
Year and Model: 1996 Volvo 854 R
Has thanked: 9 times
Been thanked: 14 times
Post by slickdizzy »
They are all 65.1.
I’m quite familiar with them :wink:
~Desmond (Current: 1996 854 R, Past: 1998 V70 GLT, 1997 855 R, 1988 744 Turbo, 1993 965)
Has thanked: 1847 times
Been thanked: 1710 times
You could get a set of hub centric wheel centers to be able to fit the 65.1mm to a 63.4mm hub long as the pitch of the bolt holes are correct. I think they are as I once bought a set of wheels that were 63.5mm centers and recall they fitted the hub pattern but of course would not fit over the hub centers. Seller said they were from a 07 P2 but were from an 08 P3.
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
As an engineer I hate spacers, they're the enemy as far as kingpin inclination goes. Back on topic, all P80s were 65.1, as dizzy confirmed.
slickdizzy
My understanding is that it’s quite easy to get earlier Volvo wheels onto the Ford-based cars as you can just utilize hubcentric rings to correct the bore, just as Neil noted.
Going the other way, OTOH, requires either machining the wheels or spacers which is probably not worth it.
(Not my pic)
Has thanked: 1504 times
Been thanked: 3817 times
slickdizzy wrote: 17 Sep 2020, 10:39 They are all 65.1.
Thats a lot of Propiii
