850 t5 ecu
desclarke
Year and Model: 850 t5
850 t5 ecu
Post by desclarke »
hi thanks for allowing me to join i have a question on the ecu which plug is a or b front or back. As i understand i need a wire from b36 to pin 7 to read fault codes but it depends which way you look at it
Cheers have owned this car for 21 years now great car
Has thanked: 1500 times
Been thanked: 3812 times
Welcome!
I’m guessing this is for a 1995 850?
Here is some info. You could use this to find the AB side by 12V presence.
viewtopic.php?f=1&t=77600
desclarke
Post by desclarke »
Hi thanks I've seen that diagram but its semetrical no front or back
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 333 times
Post by Chuck W »
desclarke wrote: 08 Oct 2020, 04:57 Hi thanks I've seen that diagram but its semetrical no front or back
That diagram tells you everything you need to know.
If you are looking at the ECU, the B-bank is on the right. If you're looking at the ECU plug(with it unplugged from the ECU), it's on the left.
The "top" of the ECU is the smooth cover side.
The "B" is the chassis side of the harness, and if you're looking down into the ECU box, it would be the connector towards the rear of the car.
