Maroon 1997 4-door sedan in good shape with minor dings associated with 165000 miles. This car has an intermittent problem with an open shift solenoid. The code is P0755/222. I would keep this car if I were sure that I could get it inspected in (NY), as this code will activate the CEL. The car runs normal 99 percent of the time with the other 1 percent being in limp mode. Otherwise everything else works. The sticker is good through August. I suspect a change out of the S2 solenoid would do the trick.
Car is located in Albany NY Area
The timing belt was changed at 130,000
The RMS Seal wash changed out at 85,000
AC Evaporator has been replaced
Private Message me for Pictures or any other questions.
$2500.00 or best offer.
1997 Volvo 850 4-Door Sedan 165,000 miles for Sale
Black Bear
- Year and Model:
Black Bear
- Year and Model:
Car has now been dealer repaired. S2 solenoid was changed and all is well with the car. I will now list the car for $ 3200 or best offer.
