92 960 timing belt cover
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
loub
Year and Model: 94,95,96 850,98S70
Post by loub »
I am replacing the timing belt on my 92 960 with 150k miles on it.
the lower rear cover was cracked , and broke in half. I ordered a new one from the dealer for $60. It seems that I will have to remove at least one cam sprocket. I do not have a cam holder. Can I just wedge a wooden dowel rod to hold the cam from moving? I plan on match marking the sprocket to the shaft and keeping the timing mark location. Is there any other things to worry about? I also replaced the water pump because I had no record of when it was replaced. Thanks.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Which engine is fitted? Different engines require different approaches.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
loub
Post by loub »
Thanks for the reply. It has a B6304 engine,I did not know there was other engine options. Any way I removed the cam sprockets by wedging channel locks in the sprocket slots. The 3 bolts holding the sprocket on to the shaft are not on real tight. Thanks again!
