Brake rotor question
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 151 times
Been thanked: 4 times
Post by Mr. Detail »
Hello all;
I need to replace my front brake rotors soon and I wondered if it is alright to replace the old standard smooth ones with a slotted/drilled rotor?
I have a 2002 V70 base model.
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Sure why not. Drilled rotors cools better but is prone to crack if you drive you car like a race car. Race cars usually just have slotted rotors for that reason.
BMW 540i 2002
S70 Base 2000
Mr. Detail
This oldhead likes to think his base model V70 is a race car but sadly my pockets are very thin. I will assume that the drilled/slotted ones won't crack with my style of driving.
Has thanked: 1498 times
Been thanked: 3810 times
It’s a great hobby, inspecting crossdrilled, titanium coated,Formula one race car brake pads on the Porsche idling next to you because a truck load of bananas overturned on the 5
Mr. Detail
Thank you sir, I needed a good laugh about now.... Monday around 4:16 ET.
Mr. Detail
On a side note, how do I correctly determine which diameter my rotors are? 286mm or 305mm?
I now have two different answers from two different sources.
kallekula
Post by kallekula »
Measure the rotor?
BMW 540i 2002
S70 Base 2000
Mr. Detail wrote: 09 Nov 2020, 14:18 On a side note, how do I correctly determine which diameter my rotors are? 286mm or 305mm?
I think the 305mm were only used on R models and had a different caliper and caliper bracket.
Try putting your VIN into volvo webstore and pulling up part numbers this way.
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
Measure your rotors, the difference is large enough great precision is not required in the measuring.
