Hi guys,
Hoping someone can help shed some light on how to clear this message.
Recently deleted the Prop Shaft, Rear Diff & CV Shafts in my 03 xc70 to convert to FWD.
Since doing so, it drives perfectly fine in FWD, but I get a "Brake Failure, Stop Safely" messaged and an ABS light.
I'm trying to figure out how to remedy this and having a hard time finding any info online about this specific issue.
Appreciate any help.
"Brake Failure" Messages after AWD Delete
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
You eliminated the rear CV shafts?BigBean wrote: 10 Nov 2020, 07:11 Hi guys,
if the wheel sensor pulse magnet is located in the inner bearing hub then it might not be rotating without the splined end of the CV shaft turning in there.
Well I just looked at the old bearing carrier I removed, maybe the pulse generator is part of the inner bearing race, without the shaft the inner race will not rotate.
I ended up in a snow filled ditch 2 yrs ago, got towed out and had ABS light plus brake failure warning, the front end was caked up with snow, after it melted away the warnings went away. Probably snow interfering with the tone ring or something similar.
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
you deleted the rear diff?...wow thats alot of work...why? i also think its got something to do with the rear sensors. might need re-programming??
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
Update: tried new sensors and also have fwd hubs on there and still no speed reading in VIDA. Interestingly the fault will not happen while VIDA is connected, and I can look at the sensor output. Both rear abs sensors rear 0.6 km/h (nearest value to 0). One side is a fwd hub and one side is the awd hub without shaft. (Only for testing purposes, once solved will have proper matching hubs)
If I connect VIDA after the fault, it will say faulty reading from both rear abs sensors.
From my research it appears the sensors are the same part between fwd and Awd. Which leads me to try to find where the reluctor/tone ring is located on FWD cars to see if I can install/replace whatever it is.
Not that much work..darrylrobert wrote: 10 Nov 2020, 23:18 you deleted the rear diff?...wow thats alot of work...why? i also think its got something to do with the rear sensors. might need re-programming??
Got the car for $300 as a winter beater, rear diff was basically seized, center support bearing for prop shaft was beyond dead.
Figured I'd rip them out to get it rolling in FWD while piecing together another and system.
If you have any idea the relation between AOC control (rear diff) and the ABS sensors you'd be a huge help haha.
The shaft missing makes sense, but I do have a fwd hub installed with same results. The FWD hub must be able to produce the signal without a shaft obviously, so I'm unsure why it's still not reading.jonesg wrote: 10 Nov 2020, 22:25
No snow here yet, nice and dry and ive cleaned the sensor and hub very well with no results.
- jonesg
the front hub has an external tone ring.
The rear hub has integrated hall sensor magnets or whatever system they use.
I recall the rear hub was quite expensive and they look identical side to side but are labelled unique to each side.
When you say rear hub do you mean the wheelbearing/hub assembly? If purchased a new FWD set so I'd assume it should be working at least on the side that's installed.jonesg wrote: 11 Nov 2020, 16:50 the front hub has an external tone ring.
- jonesg
yes the rear bearing is part of the hub. The computer is looking for the signal from the rear sensors.
There is no signal because the inner bearing race can't rotate without the drive shaft splines .
Thats my guess.
Thats my guess.
- 1858 Views
Last post by SuperHerman
- 658 Views
Last post by MrAl
- 321 Views
Last post by jonesg
- 44 Replies
- 16995 Views
- 2692 Views
Last post by MDK
