‘06 V70 NA 112k miles. Fuel gauge was at 3/4 yesterday with approx. 375 miles left to go. Today I noticed gauge at full and miles left go not decreasing after being driven about 75 miles.
I turned car off and back on and miles decreased about 20 miles. Check engine light has been coming on at 1/4 tank after last 2 fill ups. I cleared and tightened gas cap. Could these 2 problems be connected or coincidence. I have a metal fuel tank and am wondering whether I should replace fuel pump. From what I’ve been able to tell, this particular fuel pump/sending unit is one module versus the plastic tanks individual components. I did try removing #1 10a fuse at rem for 10 minutes, didn’t work. Any ideas or comments would be greatly appreciated. Thanks Glenn
‘06 Fuel pump problem?
- GlennG2759
- Year and Model: 2006 V70 NA
- Has thanked: 112 times
- Been thanked: 17 times
- Has thanked: 1506 times
- Been thanked: 3818 times
Time to read off those codes! Does sound like the sending unit. I’ll check my 2005 Alldata to see if there is anything there.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
That is very low miles. Did you drive or park on an incline ? Can't tell about the check engine light but I doubt it's a pump problem (but could be a loose cap tank indeed). The sender is only attached to the pump assembly, yet not sold separately. You may ask a garage to remove it and maybe check as shown in the video below.
- 42 Replies
- 10197 Views
Last post by Maestrours
- 4396 Views
Last post by wizechatmgr
