I am trying to figure out what sway bar is on my car without crawling underneath it, again! References to them say marked 1, or a color: red, yellow,
or blue. I would like to replace the bushings and the end links! The sway bar itself is in decent shape.
Thanks for your help on this!!!
sway bar
5rivers
- Year and Model: V70 1998 T5
- Been thanked: 14 times
sway bar
5rivers
1998 V70 M56, silver/grey, has tranny issues, #?# owner, 330,xxx miles, a handy parts car
1998 V70 AT, nautical blue, 2nd owner, 260,000 miles, Sold
1998 V70 AT, T5, forest green, 3rd owner, 172,300 miles, Mimas 16" rims
- Has thanked: 1506 times
- Been thanked: 3819 times
Is this on the 1998 base V70?
I’ll link sway bar codes table...you find these in the plate on the driver fender, under hood
Courtesy of IPD
https://www.ipdusa.com/techtips/10015/w ... it-tell-me
Courtesy of IPD
5rivers
My 1998 V70 base has the following product ID, line 20: 4F2PEVS5
So, it is marked 2. Is this referring to a color or a specific diameter of the sway bar
5rivers
Hmmm, we need the sway bar number code to diameter or color code secret decoder ring
Front swaybar diameter part #s, sizes, paint splotch colors:
9173982 O.Dia 20 mm (marked red)
9173983 O.Dia 21 mm (marked yellow)
9173471 O.Dia 21.5 mm (marked yellow/blue)
I’ll try looking at my herd this morning
5rivers
Based on the decoding table from the IPD link you provided, the anti-sway bar code is 2 - this would be item or number 21 in above table. I do not know if this helps!
5rivers
Elizabeth the T5 is sway bar code 2, I’ll go out and measure it in a bit.
What we don’t know is how to map the code numbers to the part numbers above!
Niawen!
(Trying to remember that from a road sign?)
Niawen!
Plate code 2 is 21.0 mm bar measures on two Cars this morning
It's easy to measure, just reach down with a caliper
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
- Been thanked: 112 times
My 98 V70 also has a number 2 sway bar, and the yellow marking is clearly visible (looking from the top, between the engine and firewall)
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
- Has thanked: 1851 times
- Been thanked: 1712 times
I was sure I detailed this a few years ago with color/diameter info. If I recall correctly (a 50/50 or less chance!!) The XC has the thickest swaybar at 21.5mm.
abscate wrote: ↑13 Dec 2020, 07:58 Hmmm, we need the sway bar number code to diameter or color code secret decoder ring
9173982 O.Dia 20 mm (marked red). FCP marks this as code 17 =1
9173983 O.Dia 21 mm (marked yellow) FCP marks this as code 17= 2
9173471 O.Dia 21.5 mm (marked yellow/blue). Unknown but only code 17=3 remains
- 9659 Views
Last post by SuperHerman
- 1475 Views
Last post by tomstir
