2001 Volvo S60 for $3,900 Topic is solved
Polarice70
Year and Model: 2014 V70XC
Post by Polarice70 »
Newer car forces sale of my 2001 S60. 79,500 miles, 2 owner car. No accidents. The car is gold with an Oak Interior. I have owned the car for 5 years (at 62,00 mi.). The car has an auto-stick trans. and sunroof. The timing belt and water pump were replaced 25,000 miles ago. The entire cooling system (Rad & Htr) was replaced in May. Along with that, the Engine oil pan seals and PCV were replaced. A Cera Tec oil treatment was done. An IPD sway bar was put on the front. The Engine mounts were replaced. An Aluminum skid plate (XC 90, thick) was added. Front fog lights were added in 2020.
The suspension (Sachs struts and rear shocks) and AC Compressor were replaced 17,000 mi. ago. Stainless steel brake lines and pads were added then. The rotors were replaced in 2013. The brake system has been flushed every 2 years. The Trans fluid was just flushed (drain & fill x 4) with LubriMoly 1200 fluid. Oil changes every 6-8 months with synthetic, and Mahle filters. The shift linkage and boot were replaced recently. The fuel filter was replaced and Pulstar (Plasma) spark plugs were installed a few years ago. download/file.php?mode=view&id=61228
